REVELL 1/48 B-1B back date to an A version !
Pelle F
Namn: Pelle
Re: REVELL 1/48 B-1B back date to an A version !
Inlägg av Pelle F »
JMARC skrev: 07 nov 2023, 12:33 Sure ,it's the 1896 MAXIM IN 1/48 scale, I scratch a while back ..If you like to view more pics, just follow this GOOGLE link:
https://photos.app.goo.gl/Y2KYFbhraPsSuxBN6
Enjoy !
Fantastic. Thanks.
/Pelle
JMARC
Inlägg av JMARC »
MMMMMMMMMMy pleasure !
JMARC
Inlägg av JMARC »
Here is the update on the ongoing B-1A HYBRID ..Youl'le notice there is only one image available you can view more of the update picture of the projects on the Google link !
(NOV 23th ) .. Today , I sanded the work done last time and continue to repair the front fuselage section !
If you like to help out on this projet I need these ... :
from the REVELL 1/48 B-1 LANCER stenciling for the WHITE prototype aircraft, this was on the decal sheet of the first edition of the B-1 kit.. I'm also seeking the NOSE GEAR ,LEFT STABILIZER + CREW LADDER parts .. used parts are welcome as long they are useable !
A big thank you for helping out , without your help I won't be able to do a good job on the project !...
..If you like to view more WIP of this project and 2 other 1/48 B-1 bombers ,This is 'PHASE 2' by the way follow this Google link
https://goo.gl/photos/QkeSiGZuvcRfG7yV7
JMARC
Inlägg av JMARC »
(DEC 20th ) .. Today , I sanded the work done last time , repair the damage leading edge and start to cut out panel under the capsule bay !
from the REVELL 1/48 B-1 LANCER stenciling for the WHITE prototype aircraft, this was on the decal sheet of the first edition of the B-1 kit.. I'm also seeking the NOSE WINGLETS + NOSE GEAR ,LEFT TAIL STABILIZER + CREW LADDER parts .. used parts are welcome as long they are useable !
JMARC
Inlägg av JMARC »
(FEB 06th ) .. Today , I continue cutting some more access panels but had a mist app that will need some attention later on !
JMARC
Inlägg av JMARC »
(FEB 29th ) .. Today , I continue the work in the side access panels !
from the REVELL 1/48 B-1 LANCER stenciling for the WHITE prototype aircraft, this was on the decal sheet of the first edition of the B-1 kit.. I'm also seeking the NOSE WINGLETS + NOSE GEAR ,LEFT TAIL STABILIZER .. used parts are welcome as long they are useable !
JMARC
Inlägg av JMARC »
(APR 23th ) .. Today , I continue the work in the side access panels and remove the wings !
from the REVELL 1/48 B-1 LANCER stenciling for the WHITE prototype aircraft, this was on the decal sheet of the first edition of the B-1 kit.. I'm also seeking the NOSE WINGLETS + LEFT TAIL STABILIZER .. used parts are welcome as long they are useable !
JMARC
Inlägg av JMARC »
(MAY 22ndh ) .. Today , I continue the work in the side access panels !
JMARC
Inlägg av JMARC »
(JUL 09th ) .. Today , I continue the work on the side access panels and sanded the both leading edge !
JMARC
Inlägg av JMARC »
(AUG 01st ) .. Today , I cut-up the fuselage in half !
