J.20/Re2000 F10
yury
Namn: yury
J.20/Re2000 F10
Inlägg av yury »
Hi.I shall assemble J20 from F10. Give the explanatory, please. J20 Re2000 which were with the letters for the coding (An example D E H K L) . They were with emblems of a wing or squadron?
Re: J.20/Re2000 F10
Mmm...
If I am wrong here I'l probably will be corrected quit soon but I think I'm on the right track here. At least from 1944..
The wingnumber is 10 (for F10 Flottila at Bulltofta airfield) and the color of the letters tells which squadron. Red for 1st, blue for 2nd and yellow for 3rd squadron. The yellow K letter tells that it is "gul Kalle" aircraft of 3rd squadron (yellow=gul). "Kalle" is the Swedish codeword for K as "Kilo" is the international codeword for k.
Before 1944 the individual aircraft identification was by big white numbers on fin and enginecowling.
/ Andre
yury
Namn: yury
Re: J.20/Re2000 F10
Inlägg av yury »
Thanks, for the answer. There could be emblems (lightning, bird, привидение) at codes the letters?. I have dekal " Hobby center " for J20, but it is clear only with numbers. And with such emblem of a wing at the letter of a photo did not see.
And on it an emblem?
Re: J.20/Re2000 F10
Hello Yury,
There are several decals for J20. The one that you mentioned with only (white?) numbers is for the J20 at F10 wing at Bulltofta between 1942$-1944. After that the callsigns for the aircraft where changed from numbers to letters. The emblem that can be seen on your photos is probably a "grippen" for F 10. Beore 1944 som of the J20 had lightnings on the side of the aircraft.
http://www.f10kamratforening.se/Kamrat/ ... age_id=332
Decals for J20 at F10 before and after 1944.
http://www.rebell.com/reggiane-2000-j20 ... ecals.html
/Andre
yury
Namn: yury
Re: J.20/Re2000 F10
Inlägg av yury »
Hi Andre. Thanks. Probably I shall choose with a lightning and numbers or with the letter F . Such at me http://www.rebell.com/reggiane-2000-j20 ... ecals.html there has got.
Per Börjeson
Re: J.20/Re2000 F10
Inlägg av Per Börjeson »
Just to add my two cents to any confusion....
Although the letters was introduced in 1944, they were not applied to any J 20 until 1945. Thus the number codes remained in use throughout 1944.
Regarding insignia and symbols, here's a summary of the various symbols used on the J 20. Note that they were not applied to all aircraft consistently, so photo references may come in handy when you choose what individual you'd like to build;
1st Sqn: 1st Squadron used a white ghost symbol of various size and placement. It remained in use throughout the war and was also applied to a limited number of aircraft with the 1944 marking system.
2nd Sqn: The lightning was used by 2nd squadron for a very brief time during 1942. When it became known that German units had used a similar symbol, the lightnings were removed to avoid confusion by allied pilots. It was yellow in colour, not white as some sources have claimed. 2nd Squadron never replaced the lightning with any other symbol during the war.
3rd Sqn: The blue bird (a stylized Eagle) was used by 3rd Squadron for a brief time during 1942. It was soon replaced by a Griffon insignia that remained in use from late 1942 until early 1945.
Squadron insignia were for the most part removed in 1945 with the new paint scheme. It was probably intended to use the Griffon (similiar, but not identical to the 3rd Sqn symbol) on all aircraft, but in real life only a few received it .
yury
Namn: yury
Re: J.20/Re2000 F10
Inlägg av yury »
O! Thanks Per Börjeson. The detailed explanation, is very good. I have not enough photo, but has understood. I shall begin to work above model.
Johan Elvin
Namn: Johan Elvin
Re: J.20/Re2000 F10
Inlägg av Johan Elvin »
Hi
Here is a good walkaround on the one in the airforce museum
http://www.tantopergioco.it/immagini/wa ... giane2000/
I vitrinet
J 26 P-51D Mustang
J 29F Tunnan
S 31 Spitfire PR Mk.XIX
J 32B Lansen
J 35J Draken
yury
Namn: yury
Re: J.20/Re2000 F10
Inlägg av yury »
Hi. Johan Elvin http://www.tantopergioco.it/immagini/wa ... giane2000/. At me does not open. I regret
Johan Elvin
Namn: Johan Elvin
Re: J.20/Re2000 F10
yury skrev:Hi. Johan Elvin http://www.tantopergioco.it/immagini/wa ... giane2000/. At me does not open. I regret
Strange, works for me.
Try this then, go to http://www.tantopergioco.it/ then click walkaround, aerei ad elica and scrol down to RE.2000 at the bottom.
Hope this will work for you.
I vitrinet
J 26 P-51D Mustang
J 29F Tunnan
J 32B Lansen
J 35J Draken
