AFV-CLUB överraskar rejält med en Churchill Guncarrier.
Så sent som för två veckor sedan övervägde jag en resinkonverteringssats från IMA.
Men någonstans misstänkte jag att den kunde komma i plast så det fick bli en obsyr pansarbil istället.
Ibland skall man ha tur.
Same concept Roman, a shame they dident go into serialproduction, could have made a difference. The british also had an uparmoured variant of the Vickers Light tank with a 2pdr in an open turret. Would have made a good little tankdestroyer in France 1939 -40 if they hadent cancelled the production...
If you are interested David Fletcher has written a fantastic book called "The Great Tankscandal" wich explains a lot about the poor british AFVs during the war.
Well, Erik, the tank destroyers should be short and fast. CunCarriage is a very poor example in both of these parameters when compared with StuG or Jagdpanzer IV, SU-100, etc.
And if we are talking about "early years" the Vickers with 2pdr in 1939 would not help.
A fast moving tankdestroyer with a 2 Pdr in 1939. Would be just as good as the german ones with czech 47mm guns wich were used at th same time.
The Stug is not an tankdestroyer, its an infantrysupport vehicle with a gun wich can alsobe used as an AT gun.
Same with the Churchill Guncarrier.
Whil a bit bulkier and definatly slower than a Stug from the same tome, its 3 inch gun was a more potent weapon.
Comparing to vehicles like the SU and Jagdpanzer are a bit unfair, these were later designs as well as being dedicated tankdestroyers. Its more fair to compare to ealy Stugs with the short 75mm gun (or even SIGs with the short 150mm gun).
If you want to chek out a small sleek tankdestroyer, check out the SU-1-12.
As a matter of fact there were huge differences in what to expect from a tankdestroyer in the early years. Not many peaple know that the US M8 Armouredcar was originally developed as a tankdestroyer!
The Dodgetruck with 37mm gun was an interim design awaiting the M8. When ready it was found unsuited and the design was later dug up and used as an armouredcar!
Look at the US M10, not much armour but pretty fast, just like its successer the M18. Compare these vehicles with the german "Jagd" vehicles, heavy armour and good gun but slow. Then we have the russians...
Erik, StuH were never equipped with 150 mm, only 105.
StuG III Ausf. F was produced from March 1942 with long 7.5 cm gun, and at the end of 1942 StuG III ausf G was already at the front, so it is the same period as CGC.
Weight is also important - CGC weighted twice more then StuG! Size is also half a meter taller then StuG. Speed...hm...also twice.
