God dag! from Germany - JA 37D(I) help needed
Rainer Hoffmann
- Namn: Rainer Hoffmann
God dag fellow modellers,
sorry for not speaking Swedish, but I guess most of you guys speak English, so here goes.
My name is Rainer and I'm located in northern Germany. I'm currently scratch building a 1/24 scale JA 37D Viggen (F4 52). You can find a WIP at LSP http://forum.largescaleplanes.com/index ... opic=45415.
As you perhaps can imagine, such a project requires a lot of information on the subject. And there is the problem. Unfortunately the publicly available information on the Viggen is rather scarce. Lars Befring (I believe, he is a member here) has been of great help by providing me with invaluable information (thanks again, Lars) and pointed me to this website for more help.
So if anyone here is familiar with the Viggen, especially the JA, or can point me to whatever information on this formidable fighter, I would be most grateful for the input. At the moment I'm mostly looking for the following information:
- cockpit details (of course, that's always needed I guess), especially the area behind the bang seat
- external details of the gun pack
- engine details, especially the afterburner section and nozzle
- thrust reverser section
Would it be helpful if I post the WIP here on IPMS Stockholm as well? Perhaps it would draw the attention of the the Viggen experts?
Many thanks in advance and happy modelling!
Greetings from Germany
Rainer
Rainer
Re: God dag! from Germany - JA 37D(I) help needed
I am fairly certain that a WIP (In the Works) would be appreciated, even by those of us who are not into aircraft modelling at all
About a week ago I went to the Aeroseum museum here in Gothenburg and I took a bunch of detail photos of the Viggens and Viggen cockpits they have there. It´s a mix of JA, AJS and AJSH, but if you know your Viggen you will probably figure out what is what. Do note that the aircraft are museum examples, so they are not necessarily complete. The AJS cockpit is open for the public and worn and battered as a result.
Here is the link:
http://www.plasticwarfare.se/2014/11/viggen-details/
There is also a WIP of the Tarangus 1/48 kit at ARC that might be of interest:
http://www.arcforums.com/forums/air/ind ... pic=279927
Best regards
Erik G
Here is the link:
Best regards
Erik G
Please note that while they do have a JA 37D (or Di) cockpit at Aeroseum, it has had all the interesting bits removed. I did manage to get a poor pic of the new throttle grip.. but check the arc-thread, it contains more info.
Rainer Hoffmann
Thanks a lot , Eric. I'll download those pics for sure!
Robin, I'll start a WIP soon, thanks for your input.
Best regards
Rainer
Best regards
Rainer
Very interesting and awesome build, Rainer!
Rainer,
If I were you I would start with the cockpit. Sort of pointless to build the rest of the plane and then feel like giving up due to lack of information about the cockpit. The cockpit, maybe with the surrounding section of fuselage can always be shown off as a model on its own.
Rainer Hoffmann
Thanks a lot guys, Eric's pictures did answer some of my questions already!
Robin, I started with the fuselage, but I'm working on the cockpit as well. The Raketstol 37 is almost finished, just the seat belts and buckles are missing. I didn't want to start working on the cockpit without knowing how much space there actually is inside the fuselage. Now I have a good feeling of the size of the cockpit tub and I can work on the IP and side consoles.
Regards
Rainer
Regards
Rainer
Hi Rainer, I looked at your build thread at LSP. Impressive!
I´ll probably steal your cross sectional drawings for a future 3d model.
I saw that someone posted interior pics in your thread. Beware that they were all of AJ 37, not the JA 37D.
The JA cockpit differed in many ways from the AJ, and the JA 37D even more.
It might not be important in 1/72 or even 1/48, but it might be mode visible in 1/24.
Take the throttle lever as an example.
In the older versions it was a relatively simple handle with a few buttons. On the 37D it was modified to be more HOTAS-capable.
Rainer Hoffmann
Hi Eric,
thanks a lot for your input.
I'm aware that most of the cockpit pictures that can be found on the web or elsewhere are not from the JA Mod D. But it is sometimes quite difficult to decide, which pics are from the JA. So, any help on this is very much appreciated. I'm going to start a WIP thread here, so may be, along the way you and others might be of additional help.
You are of course free to "steal" my cross sections. If you want them as EPS or PDF files, just let me know. However, I can not vouch for their accuracy, as I just made them up from pictures and a lot of eyeballing...
Regards
Rainer
Regards
Rainer
